Hi everyone,
I use evcc and most of it is self explanatory.
During migration of the yaml into the UI I recognized that in yaml there is a name
to identify the vehicle.
This is not the case in the UI.
However, if I want to select the vehicle in the UI I can do this using the title.
When I try to select the vehicle with the evcc entity select.evcc_garage_vehicle_name
it’s not working because there is no name assigned using the UI to create the vehicle.
Is there any way to use the UI and still be able to select the vehicle using the select entity above?
