for some reason I don’t get my automations running with the Sunset/Sunrise event…
Below my code…
I Don’t fully get what I am doing wrong here…
Should I change it to state change (from - to)
Your indentation is wrong for your conditions. This is what it should look like.
condition:
- condition: or
conditions:
- condition: state
entity_id: input_select.dieter_status
state: 'Home'
- condition: state
state: 'Away'
- condition: state
state: 'Vacation'
Personally, I dislike these nested conditions because the yaml is confusing and verbose. If you were interested, you could try using a template which would shorten it up. But then you might need to learn some jinja2.
condition:
- condition: template
value_template: "{{ states('input_select.dieter_status') in ['Home','Away','Vacation'] }}"
I am the only one resident in the house, so I linked it to my name.
I will change it once I am happy with all my automations to a “group” base.
(will be a group of one person though, but will be easier in the long run if I need to add somebody to the household)
Petro,
Is there a way to “block” Input Selections from being changed?
Basically I would like to make a kind of “Media Center Page”
TV On/Off
HDMI Selection (1=TV Decoder / 2=Kodi / 3=…)
Channel Selection
I would like to block changes on HDMI Selection and Channel Selection if the TV is not on.
Hmmm, you could do that with lovelace but it you’d need to create input_selects based on context. Then use a conditional card to show the correct input_select. Other than that, I don’t think you can dynamically hide/change input_select options when HA is up and running.
