Everspring ST814 Temp & Humidity stop to update
Hi everyone,
I have an EVERSPRING ST814 temperature and humidity sensor that no longer reports changes in temperature or humidity.
I tried to exclude and include the sensor again. I’m even trying to reset my z-wave key.
All of my other z-wave devices are working fine.
In my case the ST814 node id is 17. I have configured it to send a report every 10 minutes.
In the Z-wave JS logs, the report is saved but the values ​​in home assistant are not updated
2021-08-04T15:14:02.796Z SERIAL « 0x010c0004001106310501220101f7                                      (14 bytes)
2021-08-04T15:14:02.815Z CNTRLR   [Node 017] [Multilevel Sensor] Air temperature: metadata updated  [Endpoint 0]
2021-08-04T15:14:02.820Z CNTRLR   [Node 017] [~] [Multilevel Sensor] Air temperature: 24.1 => 25.7  [Endpoint 0]
2021-08-04T15:14:02.823Z SERIAL » [ACK]        (0x06)
2021-08-04T15:14:02.831Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
                                  └─[MultilevelSensorCCReport]
                                      type:  Air temperature
                                      scale: Celsius
                                      value: 25.7
2021-08-04T15:14:02.876Z SERIAL « 0x010c0004001106310501220101f7                                      (14 bytes)
2021-08-04T15:14:02.878Z CNTRLR   [Node 017] [Multilevel Sensor] Air temperature: metadata updated  [Endpoint 0]
2021-08-04T15:14:02.881Z CNTRLR   [Node 017] [~] [Multilevel Sensor] Air temperature: 25.7 => 25.7  [Endpoint 0]
2021-08-04T15:14:02.883Z SERIAL » [ACK]        (0x06)
2021-08-04T15:14:02.886Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
                                      scale: Celsius
                                      value: 25.7
2021-08-04T15:14:03.414Z SERIAL « 0x010b0004001105310505014490                                        (13 bytes)
2021-08-04T15:14:03.418Z CNTRLR   [Node 017] [Multilevel Sensor] Humidity: metadata updated         [Endpoint 0]
2021-08-04T15:14:03.422Z CNTRLR   [Node 017] [~] [Multilevel Sensor] Humidity: 69 => 68             [Endpoint 0]
2021-08-04T15:14:03.426Z SERIAL » [ACK]        (0x06)
2021-08-04T15:14:03.431Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
                                      type:  Humidity
                                      scale: Percentage value
                                      value: 68
2021-08-04T15:14:03.554Z SERIAL « 0x010b0004001105310505014490                                        (13 bytes)
2021-08-04T15:14:03.558Z CNTRLR   [Node 017] [Multilevel Sensor] Humidity: metadata updated         [Endpoint 0]
2021-08-04T15:14:03.561Z CNTRLR   [Node 017] [~] [Multilevel Sensor] Humidity: 68 => 68             [Endpoint 0]
2021-08-04T15:14:03.565Z SERIAL » [ACK]        (0x06)
2021-08-04T15:14:03.570Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
                                      type:  Humidity
                                      value: 68
But on HA nothing change
Capture_zwave
Can anyone assist?
Z-Wave JS: Current version: 0.1.34
HA CORE Version: core-2021.8.0
Thanks!
Ah, I was just about to post the exact same thing.
I also tried excluding and including my ST814 but still the same issue with no temp or humidity reports - I can see in the z-wave js log it is waking up every hour but that’s about it.
Edit: I used to see in the logs for this device
“2021-04-14T13:15:41.023Z CNTRLR [Node 028] Mapping unsolicited report from root device to first supporting end
point #1
I no longer see that, I suspect that may be related to the lack of updates in HA.
Dump is here zwave_js_dump.json - Google Drive - note its device 39 now.
Did you find a solution?
My two st-814s just stopped reporting temp updates in the last month. I can do manual refreshes and they update, but it no longer automatically updates. I have the parameter for temp reporting to 1 and have tried fresh batteries, but nothing has resolved this yet.
It’s reported as an issue here
