I tried to enable Enable Ethernet with the official instructions, and I am just not able to connect the Everything Presence Pro via ethernet. It keeps defaulting to use wiki.
The settings in the device in HA (ESPHome section) and in the Zone Configurator, show that the device is set to connect via Ethernet, but in actually it’s connected only via Wi-Fi. UI I can see this in my unifi application as connected via wifi. As another confirmation, the switch port it’s connected to, does not show any connected device.
Anyone have any tips?
Anyone anyone know how to get in touch with them for tech support?
i finally got it to work on one of my two devices. It took about 30 tired. I assume it was having issue maintaining a stable connection while downloading the new firmware verison.
edit: I was using a PoE switch. It was powering on, but something was wrong with the data. I had gotten a special flat ethernet cable but switched back to a normal one.
