Everything-Remote-Blueprint
This is a blueprint for the "Everything-Remote" by @Stock-Pot
Functions:
  • The Blueprint offers collapsable section for each button and all button have single, double and long-press actions.
  • Optional names in the section keep easier overview of the functions you did inside.
  • Also you see the GPIO Names in additon to cross check with the following picture of the buttons.
Improved ESP-Home Firmware:
  • added "device name" as substitution to easier identify different remotes by the blueprint
  • There is also now a battery voltage measurement function inside including percentage calculation
    • To make this fully work you need to solder 2x 100k Ohm resistors between 3.3V and VP and GND and VP on the lolin board
    • If you did, then you just need to uncomment the section in the ESPHome FW
Setup:
  • Flash the ESPHome code to your remote via ESPHome in your HA or the webapp
  • Import the Automation to your HA -->
  • create the automation and have fun.
