I’ve installed my EVL4 which “seems” to be working properly with the Envisalink app. I can arm/disarm remotely, see when doors open etc… Unfortunately, I’ve been unable to get it to integrate with my HA. Whenever I try to arm the system using “Home Alarm”, I get the error message “Failed to call service alarm_control_panel/alarm_arm_away. ‘NoneType’ object has no attribute ‘write’”
A few things:
- I am not 100% sure that I have the “Program the Module and Vista 20P Panel” component properly done.
- Is the homealarm card the proper one to use?
- My safe watch pro keypads aren’t “Ready” due to a check 111. I can use them to arm/disarm the system
Here is my /config/configuration.yaml code (I have more zones listed than I likely have.)
Example configuration.yaml entry
envisalink:
host: 192.168.1.XXXXX
panel_type: HONEYWELL
user_name: user
password: user
port: 4025
evl_version: 4
keepalive_interval: 60
zonedump_interval: 30
timeout: 100
panic_type: Police
zones:
1:
type: ‘opening’
2:
type: ‘opening’
3:
name: ‘Back Garage Door’
type: ‘opening’
4:
type: ‘opening’
5:
name: ‘Gues Room Windows’
type: ‘opening’
6:
name: ‘Guest Bath Door’
type: ‘opening’
7:
name: ‘Family Room Windows’
type: ‘opening’
8:
type: ‘opening’
9:
type: ‘opening’
10:
name: ‘Formal Living Windows’
type: ‘opening’
11:
type: ‘opening’
12:
type: ‘opening’
13:
type: ‘opening’
14:
type: ‘opening’
15:
type: ‘opening’
16:
type: ‘opening’
partitions:
1:
entity: alarm_control_panel.home_alarm
states:
- arm_home
- arm_away
theme: Google Dark Theme
type: alarm-panel
