I’m getting two errors that keeps repeating but with different “listeners”, 0x7f79b64d08
and 0x7f7a4ff6a8
that looks like this:
Error doing job: Exception in callback <function async_track_state_change.<locals>.state_change_listener at 0x7f7a4ff6a8>
File "uvloop/cbhandles.pyx", line 64, in uvloop.loop.Handle._run
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/event.py", line 82, in state_change_listener
event.data.get('new_state'))
File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 327, in async_run_job
target(*args)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/event.py", line 103, in template_condition_listener
template_result = condition.async_template(hass, template, variables)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/condition.py", line 298, in async_template
value = value_template.async_render(variables)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/template.py", line 137, in async_render
return self._compiled.render(kwargs).strip()
File "/usr/local/lib/python3.6/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.6/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.6/site-packages/jinja2/sandbox.py", line 427, in call
return __context.call(__obj, *args, **kwargs)
TypeError: 'NoneType' object is not callable
Anyone that’s better then me at readin logs and can point me in the right direction what might be doing it?
