Hi, i’m just starting with Unifi and running into a wish…
Wouldn’t it be wonderful if there were include and exclude parameters for the Unifi integration?
So someone could block or only allow certain MAC or IP addresses?
Ok, fair enough. How can I help? I can’t program (only non-OO) but I can read code quiet well. Maybe I can help think of a solution different then this? Or is there something else I can do?
I have a network with a lot of clients. Also I tend to change a lot of them now and again. The integration as is, will add all new devices discovered immediately. However this is not how I would’ve want it. I just want two of those devices to use for presence. So I would like to just be able to define those two devices somewhere and the integration ignore the rest. That make sense?
It does, the current way of doing this would be to change the integration system setting to not track new devices and disable those you aren’t interested in.
Ok, but every time I install the integration it adds all devices. Can I turn off my cloud key, add the two devices, and then turn the cloud key on? Because it’s not a pretty job to have dozens of disabled devices.
