Hi there,
I´ve portated my HomeAssistant Supervised-Installation to the Core-Setup, cause I allways got trouble with updating the containers. The most is working like a charm, but since the change some HACS-Excensions are not working, when accessing them from external:
Example - access local via http://192.168.200.100:8123:
Example - access via https://hass.myexterinaldomain.eu:
I´m using the offical Docker-Image (https://github.com/home-assistant/core) and there are no errors in the logs. Some HACS-Extensions are working (f.e. Scheduler Card, vacuum card), some not (f.e. rgb-color, simple thermostat, slider entity row).
For reverse proxy I´m using docker-nginx-proxy-manager (https://github.com/jlesage/docker-nginx-proxy-manager).
I have reinstalled the broken exensions, but that´s not helping - what have I fucked up?
