How do I progress this issue? I wish to display a “Statistic Graph” card but at the bottom of the list of avalable Entities to add, I read this " Expected data source not listed". And, of course, it is not listed!
The entity, in my case, is called:
sensor.xy_md02_temp
… and is from an ESPHome device:
esphome:
esp8266:
#board: d1_mini_pro #This is the actual board. But sometimes the OTA will fail?
board: esp01_1m #The compiler "says" that this will always work!
# Enable logging
logger:
baud_rate: 0
level: VERY_VERBOSE
# Enable Home Assistant API
api:
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
domain: .peritonlane
uart:
- id: hw_uart
##Software UART use GPIO0 & GPIO04
#tx_pin: GPIO0 #marked as D3 on WiMos D1 mini pro
#rx_pin: GPIO4 #marked as D2
tx_pin: GPIO1 #marked as TX on WiMos D1 mini pro
rx_pin: GPIO3 #marked as RX
baud_rate: 9600
stop_bits: 1
parity: none
modbus:
uart_id: hw_uart
flow_control_pin: GPIO5 #marked as D1 on D1 Mini Pro
#flow_control_pin: GPIO4 #marked as D2 on D1 Mini Pro
modbus_controller:
- id: xy_md02
address: 0x01
modbus_id: modbus1
- platform: modbus_controller
modbus_controller_id: xy_md02
register_type: read
address: 0x01
value_type: U_WORD
unit_of_measurement: "°C"
accuracy_decimals: 1
filters:
- multiply: 0.10
register_type: read
address: 0x02
value_type: U_WORD
unit_of_measurement: "%"
filters:
- multiply: 0.10
The “help” message says this:
You’re configuring a statistic but you couldn’t find your source in the dropdown? That’s caused by a bug in the integration providing the entity. Integrations need to configure their entities correctly so Home Assistant knows that we need to track statistics for it and how.
Open an issue with the author of the integration and link them to Sensor Entity | Home Assistant Developer Docs.
How do I track down the author? Is it the author of ESPHome Plugin, ModBus, ModBus_Controller?
Any help will be very welcome.
Regards, M.
