Experience with Zigbee Device as a 'router'
Does anyone have experience with Zigbee switches that also function as a router (switches on fixed voltage)?
I can operate the devices in the house from the kitchen table.
Pir; endpoint
Door switch; endpoint
Switch_2; router (powered by the wall outlet)
Outside is switch_1; Router (powered by the wall outlet). This only works if I just move my laptop a 50 cm so that there is no wall in between. This is all clear.
But I understood that a switch (powered by the wall outlet) functions as a router/repeater with Zigbee.
And because switch_2 is 10 meters more at switch_1 and switch_2 can be operated from the kitchen table, I thought that switch_1 would receive the signal via switch_2.
Do I have to configate something else?
Thx for that.
Thanks, it was standard on channel 20.
Changed of channels, but remains the same. A switch does not function as a router between the other switch when I look through the visualization tool see how devices are connected.
I then converted it to channel 26
The numbers show the percentage of noise on each channel, including Zigbee traffic, wi-fi traffic (your neighbour’s as well as yours) and plain old interference.
"Energy_Scan": {
"11": 75,96022321405563,
"12": 59.15797905332195,
"13": 95,69133648577223,
"14": 23,33483723001185,
"15": 92,0598007161209,
"16": 7,659755505061292,
"17": 6,011489450827149,
"18": 8,631361812931262,
"19": 2,2107128772756957,
"20": 13,711043742539033,
"21": 17,086630587133605,
"22": 3,2311094587038967,
"23": 2,2107128772756957,
"24": 1,7132450748239665,
"25": 75,96022321405563,
"26": 92,0598007161209
Then on channel 24,
"Energy_Scan": {
"11": 93,76433891498253,
"12": 87,33047519856483,
"13": 94,48255331375627,
"14": 96.19660508390695,
"15": 92,95959997754716,
"16": 3,2311094587038967,
"17": 70,89933442360993,
"18": 9,713248103580147,
"19": 4,69985354430736,
"20": 21,09014924761344,
"21": 23,33483723001185,
"22": 4,15070068297423,
"23": 65.26028270288712,
"24": 91,05606689948522,
"25": 2,2107128772756957,
"26": 87,33047519856483
Depends on the switch. What make and model?
Hello Dirk,
Trying to pick which way the mesh is going to route is like you guessing Lottery numbers.
This model and type (€ 2,59) ‘16A Tuya Zigbee 3.0 Mini Smart DIY-schakelaar’
Device type in ZHA: TZ3000_skueekg3 TS0001
source: https://nl.aliexpress.com/item/1005007295460273.html
Works perfect :slight_smile:
Little regret not buying more than two…
ZHA recognizes them as a router.
And after add one more switch (router), same distance of the coordinator. But 6 meters next to Switch_2. It build the mesh network :slight_smile:
Oh and I had downloaded multiple network scans (/api/diagnostics/config_entry/) via diagnostics and (10 inside, 10 outside) had them analyzed by Mr. AI. But I notice that it differs from day to day, this may be because WiFi APs are set to automatic and sometimes change channels.
Power Consumption Comparison: Zigbee vs RF433 (KlikAanKlikUit) vs WiFi Smart Switches
I was curious about the power consumption between switches using Zigbee 3.0, KaKu (KlikAanKlikUit, RF433), and WiFi (LSC branded), so I decided to measure them.
Conclusion:
Switching from KaKu to Zigbee 3.0 or WiFi results in a noticeable reduction in current consumption, especially in idle state. Zigbee 3.0 switches show the lowest standby current, making them more energy efficient in the long run.
