Experiencing tons of issues setting up Home Assistant
I’m new to Home Assistant, and honestly, it’s been both eye-opening and extremely frustrating. I still don’t really understand what Home Assistant is supposed to be, and I’m learning it the hard way.
I added my Philips Hue bulbs and remotes, and now I’m trying to get the remotes working. It should be simple, but I’ve already spent hours with no success. Apparently I need a Blueprint — something the UI gives zero indication of — and these are scattered all over the internet. I have to import them manually, and it’s shocking how inconsistent the quality is. Some half-work, some don’t work at all.
I didn’t realize that using Home Assistant basically meant writing my own “drivers” (Blueprint) just to use a remote. Is this only the beginning of a bigger headache? Am I better off returning Home Assistant altogether? I wasn’t expecting a fully plug-and-play experience, but this is genuinely surprising in a bad way.
Home Assistant is a piece of home automation software that connects and integrates smart home devices and other software platforms in one place.
You do not need Blueprints at all… a Blueprint is just a pre-made automation or script where you can fill in a few fields instead of designing the automation yourself. A well-designed Blueprint should make it significantly easier to reach an automation goal, especially for new users. But, anything that a Blueprint can do can be done by an automation or script that you create for yourself.
The vast majority of available Blueprints are created by the community, each to meet their own needs and preferences, and shared in hope to help someone else out. If you don’t like how they work, create your own automation.
I don’t just want a dumb toggle. Hue remote supports fading in/out, dimming up/down and cycling through different colors. Can this be done through automation?
Don’t be disheartened. You are only just starting, once you start getting a few things working it will start making sense.
If you are new and trying to find an answer or way to do something it can be difficult to find the answer. But complaining that its difficult and not very well written is not going to get you the answers you want.
Ask a good question with details of what you have tried and you will get endless help. Complain its rubbish and you may as well give up.
A few pointers that many new users fail to understand.
The Docs will provide the latest up to date info.
HA progresses so fast a lot of info found on websites and youtube is long out of date, and often causes issues.
HA is very powerful and can do almost anything you can think of, therefore it will often take time to find a method that suits you.
There are almost always more than one way to do anything.
Here is good list of common issues.
Heads up: Getting help from AI is often the worst way, as the learning model is so far behind with the rapidly changing home automation scenario. Best read the actual documentation by Hue and HomeAssistant. There are no short cuts. The amount of effort you spend decoding the bugs from other newbies can instead be spent on gaining deep understanding on how to get to your goals.
