Export/backup of automations
Is there any way to export/backup an Automation from one HA installtion to another (on a different host)?
Sure, the automations all live in automations.yaml.
Of course, if you used device triggers/conditions/actions none of those will be valid, and if you didn’t then the odds are all the entity_ids are different too.
The easiest way to access automations.yaml (the file where automations are saved) is probably via an Add-On such as:
Remember that a second host may not have the same entity names as the first.
If this helps, :heart: this post!
I back up the whole config folder every couple of months, using CX File Explorer on an Android tablet. Very useful for reference.
Hi James.
I’ll try.
