I’m using ESPHome to display the measurements of an outdoor sensor to display temperature and humidity on a TTGO-Display.
esphome:
esp32:
board: featheresp32
font:
- file: 'slkscr.ttf'
# glyphs: [!%()+,-/_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz]
- file: 'BebasNeue-Regular.ttf'
- file: 'arial.ttf'
color:
- id: color_white
red: 1
green: 1
blue: 1
- id: color_red
red: 1
green: 0
blue: 0
- id: color_green
red: 0
green: 1
blue: 0
- id: color_blue
red: 0
green: 0
blue: 1
- id: color_orange
red: 1
green: 0.6
blue: 0
- id: color_yellow
hex: ffff00
- id: color_dark_orange
hex: ff8c00
- id: color_teal_blue
red: 0
green: 0.5
blue: 0.45
- id: color_tomato
hex: FF6347
- id: color_whiskey
hex: d29062
- id: color_dark_pink
hex: cb416b
- id: color_grape
hex: 5d1451
- id: color_lavender
hex: d5c9dd
- id: color_arctic_blue
hex: 95d6dc
- id: color_sapphire
hex: 09577B
- id: color_light_blue
hex: add8e6
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "kaLYjSYIg3WK91mgfgWlnjhtUq/KuUOB/L3fEhUA/8c="
ota:
platform: esphome
password: "eb0056095af6c6bdbe204b22bfb4adc3"
wifi:
ssid: !secret wifi_ssid
domain: ".fritz.box"
fast_connect: True
# Optional manual IP
manual_ip:
static_ip: 192.168.178.95
gateway: 192.168.178.1
subnet: 255.255.255.0
dns1: 192.168.178.1
ap:
ssid: "Display-1 Fallback Hotspot"
password: "xfoC8woX5yd9"
captive_portal:
web_server:
port: 80
spi:
clk_pin: GPIO18
mosi_pin: GPIO19
time:
- platform: homeassistant
timezone: Europe/Berlin
binary_sensor:
name: "Display Power State"
lambda: |-
if (id(vcc).state > 4.3) {
// Power is On.
return true;
} else {
// Power is Off.
return false;
entity_id: sensor.bthome_sensor_b5a3_temperature
unit_of_measurement: '°C'
unit_of_measurement: 'V'
entity_id: sensor.bthome_sensor_b5a3_voltage
entity_id: sensor.bthome_sensor_b5a3_humidity
unit_of_measurement: '%'
- platform: adc
pin: 34
accuracy_decimals: 2
attenuation: auto #11db
update_interval: 60s
filters:
- multiply: 2.0 # The voltage divider requires us to multiply by 2
lambda: |-
// I know infering the battery from voltage only is misleading, but I'll take it. Considering linear decay (again, i'll take it), max=2.23, min=1.38
// battery_percentage = 100 * (adc - BATTERY_MIN_ADC) / (BATTERY_MAX_ADC - BATTERY_MIN_ADC);
if (id(vcc).state > 4.3) {return 101;}
else {return (100*(id(vcc).state-3.3)/(4.2-3.3));}
on_value:
then:
- lambda: |-
if (id(vcc).state < 4.3) {
auto call = id(back_light).turn_on();
call.set_brightness(id(batterylevel).state/100);
call.perform();
else {
call.set_brightness(1.0);
call.perform();
# ESP_LOGI("display-1", "Value of batterylevel: %f", id(batterylevel).state);
# ESP_LOGI("display-1", "Value of backlight: %f", id(back_light).current_values.get_brightness());
# - light.dim_relative:
# id: gpio_04_backlight_pwm
# level: batterylevel.state
# Define a PWM output on the ESP32
output:
- platform: ledc
pin: GPIO04
# Define a monochromatic, dimmable light for the backlight
light:
- platform: monochromatic
output: gpio_04_backlight_pwm
name: "Display Backlight"
restore_mode: RESTORE_AND_ON
# TODO brightness
display:
- platform: ili9xxx
model: st7789v
#TTGO TDisplay 135x240
dimensions:
height: 240
width: 135
offset_height: 40
offset_width: 52
# Required or the colors are all inverted, and Black screen is White
invert_colors: true
cs_pin: GPIO5
dc_pin: GPIO16
reset_pin: GPIO23
rotation: 90°
update_interval: 15s
lambda: |-
// comment
if (id(vcc).state < 4.3) {it.printf(4, 4, id(font_slkscr_16), id(color_teal_blue), "%.1f VBat (%.1f%%)", id(vcc).state, id(batterylevel).state);}
else {it.printf(4, 4, id(font_slkscr_16), id(color_teal_blue), "%.1f VIn (Charging)", id(vcc).state);}
it.strftime(180, 16, id(font_slkscr_16), id(color_teal_blue), TextAlign::BASELINE_LEFT, "%H:%M", id(esptime).now());
it.printf(16, 18, id(font_bebas_48), id(color_white), "Temp");
it.printf(120, 18, id(font_bebas_48), id(color_white), "Humi");
if(id(bthome_sensor_094e_temperature).has_state()) {
float temp = id(bthome_sensor_094e_temperature).state;
if (temp > 24.0) {it.printf(16, 72, id(font_bebas_48), id(color_tomato), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else if (temp > 18.0) {it.printf(16, 72, id(font_bebas_48), id(color_whiskey), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else if (temp > 12.0) {it.printf(16, 72, id(font_bebas_48), id(color_dark_orange), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else if (temp > 6.0) {it.printf(16, 72, id(font_bebas_48), id(color_dark_pink), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else if (temp = 0.0) {it.printf(16, 72, id(font_bebas_48), id(color_lavender), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else if (temp > -5.0) {it.printf(16, 72, id(font_bebas_48), id(color_arctic_blue), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
else {it.printf(16, 72, id(font_bebas_48), id(color_sapphire), "%.1f°" ,id(bthome_sensor_094e_temperature).state);}
if (id(bthome_sensor_094e_humidity).has_state()) {
float humi = id(bthome_sensor_094e_humidity).state;
if (humi > 60.0) {it.printf(120, 72, id(font_bebas_48), id(color_light_blue), "%.1f%%", id(bthome_sensor_094e_humidity).state);}
else if (humi > 40) {it.printf(120, 72, id(font_bebas_48), id(color_green), "%.1f%%", id(bthome_sensor_094e_humidity).state);}
else {it.printf(120, 72, id(font_bebas_48), id(color_yellow), "%.1f%%", id(bthome_sensor_094e_humidity).state);}
text_sensor:
- platform: version
number:
<<: *AnchorDelay
name: "Main Switch Delay"
<<: *AnchorDelay
name: "Aux Switch Delay"
I have found most of the building blocks here in the forum, thank you to all contributors.
