External access
Hi there,
since last update i can not get external access neither app mobile nor web access. I have synology NAS, HA running inside a docker, certificate through let’s encrypt and always get the same error:NET::ERR_CERT_COMMON_NAME_INVALID
i have tried to renew the cerfiticate, create new one… with no success.
Any idea? thanks in any case.
Check your certificate and make sure you are using the exact same hostname to access HA. For example, a certificate for “example.com” will fail if you try to access “www.example.com”.
If this works, then you’ll need to adjust your certificate to include the appropriate variations or wildcards.
hi! thank you for your answer, but yeah i have the same hostname. The fact is i updated few versions ago and out of the blue i could not have external access. i have tried to renew my let’s encrypt certificate and nothing still not working. I am trying to acces with https://ha.hostname.me:5051 which is my https port.
It’s tricky - I understand why you don’t want to share the actual URL, but troubleshooting certs without it is a bit of a shot in the dark!
Does your common name include the port? If so, it would be worth removing it to see if that works.
Depending on your setup you may or may not need to include the port in the URL to access your instance, but from what I can tell the cert should work for any port, as long as no port is specified in the cert.
hey thank you anyway for your answer! it does not matter if i write the URL with or without port. The result is the same.
Is the domain in your certificate ha.*******.synology.me?
Hi, yes it is
Is your HA actually listening on 5051, and the synology only doing port forwarding, or is the synology acting as a reverse proxy?
hi koying, first question yes, HA is listening 5051. ( At least it seems… ). Second question, yes too, Syno is acting as a reverse proixy
no idea if it helps, but if i try to access when i am my local net, it works, i mean, 192.168.0.101:8123 works perfectly. so i guess the problem is with the certificate but i am lost…
Your certificate must be on the synology, then, because that’s where the “SSL termination” occurs.
hey! but it is already. I mean i created a let’s encrypt certificate time ago. It was running ok and out of the blue i update HA and i realized i could not have external access anymore. of course i have tried to renew it, also tried with no firewall…and nothing, always the same message…certificate not valid
Oh, ok.
Did you also trust the synology (as a reverse proxy) on HA side?
It’s mandatory since a couple versions
where and how do you do this ? not sure if it is done
Hi!
I’m having the exact same issue. Have you been able to fix it?
