Yes, that was exactly what I was looking for … thanks for pointing me in the right direction
Unfortunately, the reference samples are not correct and the format needs to be adjusted. The below sample is working
[{“id”:“8d868ab0.252df8”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:540,“wires”:[[“312e7759.0f61f8”]]},{“id”:“312e7759.0f61f8”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“on”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“1”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:540,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“c0271d68.bc6f3”,“type”:“mytimeout”,“z”:“62edd340.699ffc”,“name”:“My Timeout”,“outtopic”:“”,“outsafe”:“on”,“outwarning”:“Warning”,“outunsafe”:“off”,“warning”:“5”,“timer”:“30”,“repeat”:false,“again”:false,“x”:450,“y”:580,“wires”:[[“ba9a29fa.e838d8”],[“208cab71.bd6584”]]},{“id”:“ba9a29fa.e838d8”,“type”:“debug”,“z”:“62edd340.699ffc”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“x”:670,“y”:560,“wires”:},{“id”:“208cab71.bd6584”,“type”:“debug”,“z”:“62edd340.699ffc”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:670,“y”:600,“wires”:},{“id”:“a40de116.0d3c6”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“off”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“0”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:580,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“41e2d61d.5e3a98”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“200”,“rules”:[{“t”:“set”,“p”:“timeout”,“pt”:“msg”,“to”:“200”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:760,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“3a828d90.89a902”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“600”,“rules”:[{“t”:“set”,“p”:“timeout”,“pt”:“msg”,“to”:“600”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:640,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“e9e0c500.901a28”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“300”,“rules”:[{“t”:“set”,“p”:“timeout”,“pt”:“msg”,“to”:“300”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:680,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“ee1c8088.33ed2”,“type”:“change”,“z”:“62edd340.699ffc”,“name”:“150”,“rules”:[{“t”:“set”,“p”:“timeout”,“pt”:“msg”,“to”:“150”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:250,“y”:720,“wires”:[[“c0271d68.bc6f3”]]},{“id”:“7ec8efef.8e7cd”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:580,“wires”:[[“a40de116.0d3c6”]]},{“id”:“7d3a748d.62994c”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:760,“wires”:[[“41e2d61d.5e3a98”]]},{“id”:“72d605d1.cdb7dc”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:640,“wires”:[[“3a828d90.89a902”]]},{“id”:“cf60761e.9fc138”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:680,“wires”:[[“e9e0c500.901a28”]]},{“id”:“bffd79f5.860cf8”,“type”:“inject”,“z”:“62edd340.699ffc”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“”,“once”:false,“onceDelay”:0.1,“x”:100,“y”:720,“wires”:[[“ee1c8088.33ed2”]]}]
