but #8 is not working for me:
when i look at the _cost en _compensation, the price is not right, the reset moment is also not right. How can i get the grid total cost?
If you look at your cost and compensation sensors for today, you see visually the increments were 0.69-0.40 for cost and 0.85-0.17 for compensation. So the total cost was approximately 0.69-0.40-(0.85-0.15) = -0.41, so that’s your -0.43 (small difference because I read the numbers from the chart).
So what you need is a template sensor or helper that computes the difference between the cost and compensation. And then you can use that in the chart without changing anything.
No you take netto = cost - compensation. The card will compute what the total amount netto for the time period 00:00 - 23:59 is. This is netto (at 23:59) - netto (at 00:00). This is the same as the energy dashboard does
it’s not working look at the card on the right side at my preview post
what i can do is make 2 utility meter and reset the every day,
it’s very ugly but don’t know how i can make it work, it should work right out of the box i was hooping
but i’m afraid that it not going to work, it looks like the building in sensor will be reset at the middle of the day, i don’t understand what is going on
Have you read Q11 in the FAQ? Use the charts there with this sensor you just made and it should work. It will take some hours to calculate statistics though.
