Hey Rob,
I have checked out your github and i got facebox running. Just a quick question. Does facebox gets triggered when it detects a face and does the recognition or do i trigger it with a motion sensor?
Edit: Can i also run a live camera feed into facebox?
OK I’m revisiting Facebox but stalling at the first hurdle. Upon launching the Facebox docker I’m getting the following error:
[CRITICAL] command exited during start up, make sure the container has enough RAM available to start, check out https://machinebox.io/docs/setup/docker#minimum-requirements
stderr
Now I have a DS918+ with 4GB which worked fine when the Facebox integration was first launched. The link above states at least 4GB needed which differs from the 2GB thats listed on the components page.
Well that’s looks good, I’ll give it a go. I posted on Machinebox slack re the issues and got this reply:
probably is not memory, is that machine does not have AVX instructions, so it does not run try Docker for that machine, but as a big warning, is an image that is not maintain, or officially supported
Still can’t seem to get the HA service to teach Facebox so had to revert to using ‘Paw’ (https://paw.cloud) to send a POST request through to my instance of Facebox. Still getting my logs flooded with the following error however:
Failed to parse headers (url=http://192.168.1.117:2971/camera/stream): [StartBoundaryNotFoundDefect(), MultipartInvariantViolationDefect()], unparsed data: ''
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 396, in _make_request
assert_header_parsing(httplib_response.msg)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/response.py", line 66, in assert_header_parsing
raise HeaderParsingError(defects=defects, unparsed_data=unparsed_data)
urllib3.exceptions.HeaderParsingError: [StartBoundaryNotFoundDefect(), MultipartInvariantViolationDefect()], unparsed data: ''
That error appears to be related to the camera. The facebox component will return facebox specific errors on a failed teaching attempt, e.g. if there is no face present in an image.
EDIT: to trouble shoot, set the SCAN_INTERVAL: 1000 as this will disable the auto scan every 10 seconds, see if this halts the error
Yes try calling the scan service manually. A scan requests a new image from the camera, then processes the new image. So I think the error you are getting is due to the request for a new image
Yeah manual scan gives the error again, but detects the face ok.
It’s a ha camera entity I’m using but the end point is as follows:
Is it expediting something else hense the parsing issue?
EDIT: I swapped out the camera entity for another camera entity in my HA instance and the error isn’t happening. The camera entity in this instance is a ffmpeg where as the entity that I was having issues with was a mjpeg.
