Fail to install HA on proxmox
Truing to resinstall and get this meesge
I have a new installation of proxmox and followed this insteuction:
Is there any recent guide that can show a clean install on HA on proxmox I can use?
I got one try going but the HA did not get any IP and now it just fail to boot at all…
Help very much appreciated…
I think I now got the system to boot but I cannot access it.
noIP
The proxmox VM does not like to get me a IP adress…
I hope anyobe can help…
Now I am able to boot and the issue was secure boot on the VM.
After rebooting the VM in proxmox and hitting escape i could get into the secure boot config on the VM console and disable it.
(“attempt secure boot” should be disabled)
After this I needed to enable QEME guest agent in proxmox for the VM (options menu).
Not sure if I am the only person in the world experianceing this but I share my babysteps if anyone need :slight_smile:
Can I a little more clarification of the solution. I’m new to VMs. It not the machine bios you are changing but the home-assistant vm that you created in proxmox?
So when you tell the home-assistant vm to start, you hit escape in the console window of that VM?
Thank for any pointers…
All good. I found this Home Assistant VM Stuck And Won't Boot On PROXMOX 7.x - YouTube
Filled in the missing gaps
Hello I am new at Proxmox and at Home Assistant.
On two Machines I could Install Home Assistant but now after installing there is an Error at line 431 see below.
Using Disk Cache: Default
Using Hostname: haos10.5
Using CPU Model: Default
Allocated Cores: 2
Allocated RAM: 4096
Using Bridge: vmbr0
Using MAC Address: 02:4F[image]E:21[image]C:5A
Using VLAN: Default
Using Interface MTU Size: Default
Start VM when completed: yes
Creating a HAOS VM using the above default settings
✓ Using local-lvm for Storage Location.
✓ Virtual Machine ID is 100.
https://github.com/home-assistant/operating-system/releases/download/10.5/haos_ova-10.5.qcow2.xz
✓ Downloaded haos_ova-10.5.qcow2.xz
✓ Extracted KVM Disk Image
✓ Created HAOS VM (haos10.5)
✓ Started Home Assistant OS VM
✓ Completed Successfully!
^C
bash: -c: option requires an argument
[ERROR] in line 431: exit code 2: while executing command bash -c
root@pve:~#
What can i Try now?
This the Log of Proxmox
Aug 26 12:50:36 pve qm[182480]: root@pam starting task UPID:pve:0002C8D1:007BE2DA:64E9D8FC:qmcreate:100:root@pam:
Aug 26 12:50:36 pve qm[182480]: root@pam end task UPID:pve:0002C8D1:007BE2DA:64E9D8FC:qmcreate:100:root@pam: OK
Aug 26 12:50:46 pve qm[182553]: root@pam update VM 100: -boot order=scsi0 -description # Home Assistant OS
GitHub - tteck/Proxmox: Proxmox VE Helper Scripts
ko-fi -efidisk0 local-lvm:vm-100-disk-0,efitype=4m -scsi0 local-lvm:vm-100-disk-1,discard=on,ssd=1,size=32G
Aug 26 12:50:48 pve qm[182560]: root@pam starting task UPID:pve:0002C921:007BE788:64E9D908:qmstart:100:root@pam:
Aug 26 12:50:48 pve qm[182561]: start VM 100: UPID:pve:0002C921:007BE788:64E9D908:qmstart:100:root@pam:
Aug 26 12:50:48 pve systemd[1]: Started 100.scope.
Aug 26 12:50:49 pve kernel: device tap100i0 entered promiscuous mode
Aug 26 12:50:49 pve kernel: vmbr0: port 2(tap100i0) entered blocking state
Aug 26 12:50:49 pve kernel: vmbr0: port 2(tap100i0) entered disabled state
Aug 26 12:50:49 pve kernel: vmbr0: port 2(tap100i0) entered forwarding state
Aug 26 12:50:49 pve qm[182560]: root@pam end task UPID:pve:0002C921:007BE788:64E9D908:qmstart:100:root@pam: OK
Aug 26 12:50:52 pve qm[182622]: root@pam starting task UPID:pve:0002C962:007BE929:64E9D90C:qmstop:100:root@pam:
Aug 26 12:50:52 pve qm[182626]: stop VM 100: UPID:pve:0002C962:007BE929:64E9D90C:qmstop:100:root@pam:
Aug 26 12:50:52 pve kernel: vmbr0: port 2(tap100i0) entered disabled state
Aug 26 12:50:52 pve qmeventd[570]: read: Connection reset by peer
Aug 26 12:50:52 pve systemd[1]: 100.scope: Deactivated successfully.
Aug 26 12:50:52 pve systemd[1]: 100.scope: Consumed 4.057s CPU time.
Aug 26 12:50:53 pve qm[182622]: root@pam end task UPID:pve:0002C962:007BE929:64E9D90C:qmstop:100:root@pam: OK
Aug 26 12:50:53 pve qmeventd[182639]: Starting cleanup for 100
Aug 26 12:50:53 pve qmeventd[182639]: Finished cleanup for 100
Aug 26 12:50:54 pve qm[182640]: root@pam starting task UPID:pve:0002C971:007BEA0D:64E9D90E:qmdestroy:100:root@pam:
Aug 26 12:50:54 pve qm[182641]: destroy VM 100: UPID:pve:0002C971:007BEA0D:64E9D90E:qmdestroy:100:root@pam:
Aug 26 12:50:54 pve kernel: dm-7: detected capacity change from 67108864 to 0
Aug 26 12:50:55 pve kernel: dm-6: detected capacity change from 8192 to 0
Aug 26 12:50:55 pve qm[182640]: root@pam end task UPID:pve:0002C971:007BEA0D:64E9D90E:qmdestroy:100:root@pam: OK
Aug 26 12:55:10 pve systemd[1]: session-31.scope: Deactivated successfully.
Aug 26 12:55:10 pve systemd[1]: session-31.scope: Consumed 56.046s CPU time.
Aug 26 12:55:10 pve systemd-logind[554]: Session 31 logged out. Waiting for processes to exit.
Aug 26 12:55:10 pve systemd-logind[554]: Removed session 31.
Could you provide the specifications of your machine?
Amazon:
Mini PC, Intel Celeron Processor J4125 Quad-Core CPU 8 GB DDR / 256GB SSD Mini Desktop Computer mit Windows 10, HDMI- und DP Anschluss, Dual Band WiFi 2,4+5.8 G, BT 4.2, 4*USB 3.0
Proxmox:
CPU(s)
4 x Intel(R) Celeron(R) J4125 CPU @ 2.00GHz (1 Socket)
Kernel Version
Linux 6.2.16-10-pve #1 SMP PREEMPT_DYNAMIC PMX 6.2.16-10 (2023-08-18T11:42Z)
PVE Manager Version
pve-manager/8.0.4/d258a813cfa6b390
Repository Status
Proxmox VE updates Non production-ready repository enabled!
Dual NICs?
I will check if and how. Just I will ask a friend. Answer coming soon?
Peripherals Interface
RJ45 Gigabit Ethernet Port×2, USB 3.0 Port×4, TF Card Slot×1, DC Jack×1, Digital MIC×1,MIC×1
1 * Gigabit Ethernet
I think there is no dual NIC.
Is it possible to give proxmox a dual NIC?
Now it works, I installed with video from Simon 42. Thanks for your suggestions. Bye Franz
