Running HA 0.84 on Raspbian 9.6
My HA fail2ban card is showing:
The following components and platforms could not be set up:
sensor.fail2ban
Please check your config.
I have configured it as per instructions:
https://www.home-assistant.io/cookbook/fail2ban/
which reads:
In addition, Home Assistant must be able to read the fail2ban log file.
configuration.yaml includes…
- platform: fail2ban
jails:
- ha
- nginx-botsearch
- nginx-http-auth
- sshd
- sshd-ddos
file_path: /var/log/fail2ban.log
scan_interval: 5
This issue may have to do with file_path. In the past I have changed permissions from
pi@raspberrypi:~ $ ls -al /var/log/fail2ban.log
-rw-r----- 1 root adm 35221 Jan 9 09:31 /var/log/fail2ban.log
to
-rw-rw-rw- 1 root adm 35221 Jan 9 09:31 /var/log/fail2ban.log
to temporarily solve the problem and the sensor works ok UNTIL at some point fail2ban resets permissions to
so the error is back.
Adding homeassistant user to adm group might solve it but… is that the expected way to go?
Please, kindly share your thoughs.
Thank you in advance,
