hi,
i am trying to install eq3bt with
sudo pip3 install python-eq3bt
and then get an error and it wont install.
what am i doing wrong?
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-wt2chsgc/bluepy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-cdpw6hgl-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-wt2chsgc/bluepy/
regards,
jens
