Hi everyone,
I am runnning HA on VirtualBox,
Home Assistant 2022.10.1
Supervisor 2022.09.1
Operating System 9.0
Frontend 20221006.0 - latest
I installed Telegram and I am getting the following error:
Logger: homeassistant.setup
Source: components/telegram_bot/init.py:339
First occurred: 23:04:23 (1 occurrences)
Last logged: 23:04:23
Error during setup of component telegram_bot
File “/usr/src/homeassistant/homeassistant/setup.py”, line 235, in _async_setup_component
result = await task
File “/usr/src/homeassistant/homeassistant/components/telegram_bot/init.py”, line 339, in async_setup
if not config[DOMAIN]:
KeyError: ‘telegram_bot’
Source: setup.py:182
Unable to set up dependencies of telegram. Setup failed for dependencies: telegram_bot
Source: setup.py:184
Setup failed for telegram: (DependencyError(…), ‘Could not setup dependencies: telegram_bot’)
As usual, I might be missing a comma or a small letter. I appreciate your feedback. Thank you
