Failed to add ZHA integration
I have conbee II USB stick inserted to the laptop which running docker HASS.
I think the device is at /dev/ttyACM0
Tried to add ZHA integration, but it didn’t detect the device. Tried manually add it and submit it failed with message: Unable to connect to ZHA device.
What else I need to do to add this integration? Thanks!
Did you add the path of your Z-Wave stick to yoir docker run command or to the docker-compose stack? The USB path needs to be mounted to the docker container.
Yes I added /dev/ttyACM0 to the docker compose file, rebooted HA. Just figured out that I need to restart container itself.
