Failed to communicate with IP Webcam when turning background
Hello, guys:
I just confgiured IP Webcam in my phone. I can connect it with tinyCam Monitor as well as home assistant. Then I pressd the home key on my phone to make it running background. Of course, I can also connect it with both tinyCam and home assistant. But when I restart home assistant and login again, it an never connect the IP camera and shows error message like
2018-12-06 13:28:14 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 10.11.12.53:8080 ssl:None [Connect call failed (‘10.11.12.53’, 8080)]
And tinyCam Monitor still works well. So I switch IP Webcam to foreground. Then the connection is back to normal.
Here is configuration of webcam:
android_ip_webcam:
  • host: 10.11.12.53
    port: 8080
    scan_interval: 10
    sensors:
    • audio_connections
    • video_connections
    • battery_level
    • battery_temp
    • light
    • motion
    • pressure
      switches:
    • exposure_lock
    • ffc
    • focus
    • gps_active
    • night_vision
    • overlay
    • torch
    • whitebalance_lock
    • video_recording
      motion_sensor: TRUE
I have the same issue, did you ever get this solved?
Same problem here
