Since upgrading from 0.112.x to 0.113.3, (edit: also tried now with 0.114) HA fails to connect to my MQTT server.
This is the error:
2020-08-03 22:13:03 ERROR (Thread-8) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2020-08-03 22:13:03 WARNING (Thread-8) [homeassistant.components.mqtt] Disconnected from MQTT server mqtt.flespi.io:1883 (5)
I also tested with another MQTT server, who failed with this error:
2020-08-03 22:10:27 WARNING (Thread-8) [homeassistant.components.mqtt] Disconnected from MQTT server mqtt.dioty.co:1883 (1)
Not a clue. I have 3 instances of HA, all upgraded to 0.113.x, and the all connect fine to my mqtt server. It is not an external one, but my mqtt server runs on a separate Pi.
Still with this issue. I thought that maybe with 0.114 it will work. It didn’t.
I also tested the following:
removed the MQTT settings from the configuration.yaml file and added the MQTT through the Integrations panel. the process ends successfully, but still no MQTT communication and in the log I can fiind many entries like:
2020-08-13 20:32:09 ERROR (Thread-26) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2020-08-13 20:32:09 WARNING (Thread-26) [homeassistant.components.mqtt] Disconnected from MQTT server mqtt.flespi.io:1883 (5)
When I go back to 0.112.3 - all works as expected, either through the configuration file or by the integrations panel.
Any help will be highly appreciated as it prevents me from upgrading.
As last resort I assume I will have to reinstall everything from scratch but is something I really try to avoid…
So I took the step of loading a fresh new hass.io version (0.114.3). Once loaded, I only logged in using the welcome wizard and then headed to add MQTT using the integrations option on the configuration menu. It ended successfully and then I headed to the core logs just to find out the same error as before -
2020-09-02 12:19:27 ERROR (Thread-8) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2020-09-02 12:19:27 WARNING (Thread-8) [homeassistant.components.mqtt] Disconnected from MQTT server mqtt.flespi.io:1883 (5)
