Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225
So ZHA has decided to flip the table and just not work. Out of 49 devices i have 3 sensors working (great!). In the logs I can find this:
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 68, in wrap_zigpy_exceptions
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 86, in wrapper
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1359, in handler
  File "/usr/src/homeassistant/homeassistant/components/zha/switch.py", line 57, in async_turn_on
  File "/usr/local/lib/python3.13/site-packages/zha/application/platforms/switch.py", line 95, in async_turn_on
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/general.py", line 465, in turn_on
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 85, in wrapper
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 77, in wrap_zigpy_exceptions
    raise ZHAException(message) from exc
zha.exceptions.ZHAException: Failed to send request: Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225>
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1361, in handler
Nothing I’ve found really seams to fit my situation. I have a Conbee (I/1) and people seems to be pointing at interference. It just seems a little odd that all the mains powered devices would out-interfered but some battery powered devices (not close by) are not.
The whole situation feels odd and I can’t say for certain but it feels like this started (or at least started getting worse and then ending in this catastrophe) when/after upgradeing to Home Assistant Core 2025.4.3
Other versions are:
  • Supervisor 2025.04.0
  • Operating System 15.2
Hi @stefan.nitsche
Did you find a solution for this? I´m still strugling with my system.
