Failed to install the Matter Server add-on
Hi everyone,
This is my first post here.
I’ve installed a Home Assistant VM using UTM, and I’m getting this error when trying to install Matter:
“Failed to install the Matter Server add-on.”
I also have a notification saying that I don’t have enough storage: 4.7 GB used out of 5.2 GB.
Since this is a VM, how can I increase its disk size?
Thanks for your help!
Lynx
You increase the storage media size in your hypervisor and then you restart HAOS.
You need restart the entire system, not just HA Core.
Hi WallyR I have not found where I can increase the size on my VM using UTM I m still looking for it …
That would be somewhere in UTM and not HA, so I can not help there.
I have found the setting was quite simple finally thanks for your help lake of place lead that I could not install Matter it is all good now
