Failed to perform the action climate/set_hvac_mode. unknown error
ive got a hive hub and using the Theromate card, but just over the last couple of days ive been getting a error : Failed to perform the action climate/set_hvac_mode. unknown error
tried looking up the logs but no errors show up also tried reconfiguring my hive hub and again nothing :frowning:
Anyone got any ideas what could be causing the issue :frowning: ?
Have not got the answer but interesting that you have this issue. I have had exactly the same issue with my Hive system. Was all working fine with no issues until 2 days ago. I can see the temperature been updated in HA if I update in the native Hive app but can control in HA.
so it seems its a hive integration issue, already been fixed,
sadly next update is due on 21st February, so no hive automations for a week
Hi - glad I found your post!
I am a new user to HA, and trying HA because my basic Apple Home ‘if HomePod in kitchen says it’s cold turn on HIVE heating’ automation wasn’t working (even though it works when you press "test now’) in the hope this might perform better.
And it seems I downloaded it just as this fault was a live issue. Roll on tomorrow’s update! and hoping for a fix, because I think I could get right into this platform.
