Failed to start bluetooth: passive scanning on linux requires BlueZ >= 5.56
I got this home assistant error:
failed to start bluetooth: passive scanning on linux requires BlueZ >= 5.56 with --experimental enabled and Linux kernel >= 5.10; Try power cycling the Bluetooth hardware.
I installed it through docker on a raspberry pi zero 2W
Hello vespuccio,
How is this related to Home Assistant?
If you are trying to run Home Assistant on a raspi zero it is not recommended hardware and will not work properly.
Hi!
I have Home Assistant in docker (2025.3.1) and since 2-3 days the bluetooth devices doesn’t work, with this error in bt integration:
Error de configuración, se volverá a intentar: hci0 (E4:70:C7:88:6D:86): hci0 (E4:70:C7:88:6D:86): Failed to start Bluetooth: passive scanning on Linux requires BlueZ >= 5.56 with --experimental enabled and Linux kernel >= 5.10; Try power cycling the Bluetooth hardware.
Had the same error. Docker on RPi3. Fixed that by editing /etc/bluetooth/main.conf, uncomment and set “Experimental = true”, restart bluetooth service (systemctl restart bluetooth).
This worked for Beelink EQ14 with HAOS 16 as well. Thanks
nm, it failed shortly after because the /etc/bluetooth/main.conf seemed to reset back to false.
