Hey all,
I have two network subnets: one for LAN (10.0.0.x) and the other for WIFI (10.1.0.x).
I setup a router between the two networks and added a static route to allow network communication.
My Home Assistant server (hassio on RPI3) is connected to the LAN subnet and I have 2 Yeelight ceiling lamps connected to the WIFI subnet.
I activated Lan Control on both lamps and tried adding them using the Integration panel. Since (unfortunately) the discovery won’t work between subnets, I specified the IP address of each lamp, but got “Failed to connect” error for both IP’s.
So I tried using the “old way” and added to the configuration file the following:
yeelight:
devices:
10.1.0.13:
name: Ceiling Light 1
model: ceiling1
Restarted Home Assistant and found the following error in the log:
- Failed to get capabilities from 10.1.0.13: timeout
I tried pinging the IP from the HA server terminal to test connectivity and it worked as expected.
What else can I try?
BTW - I have the WLED integration working with the same configuration - the WLED device is on the WIFI subnet and I had no problem adding and controlling it.
