Failing to install HAC - New to Home Assistant
Hi I am trying to install a Seplos inverter bluetooth integration which is delived by HAC’s. Trying to install HAC’s but get the following failure:
2026-04-28 16:29:41.833 ERROR (MainThread) [supervisor.addons.addon] Could not pull image to update app cb646a50_get: failed to prepare extraction snapshot “extract-796564665-za9W sha256:03b637180e00c561b55d74c07840e0d19eeb93cf70c2ac20a8cba5700101a5a7”: failed to stat parent: stat /mnt/data/docker/containerd/daemon/io.containerd.snapshotter.v1.overlayfs/snapshots/432/fs: no such file or directory
Can anyone tell me what I need to do?
I tried about half a dozen times to install it with the same error.
The good news is that I left it overnight - tried again today and it installed without any problem.
When you have just installed HACS the download of integrations data can cause a rate limiter at GitHub to be activated and that might be the case here.
After a while HACS have retreived what it needs and from then on it works as expected.
