Failing to load frontend after configuration change
I’ve been using the default weather plugin since I started so I decided to change it. I’ve tried Dark Sky and Wunderground but each time I put in a new weather sensor my front end fails to load after a reboot. I have to remove them from the configuration do a “host reboot” before it comes back up.
Any idea what is going on here?
This might be cargo-cult thinking but, assuming errors aren’t showing up in the home-assistant.log (are there any?), restarting through the hass.io menu seems more consistent to me than through the configuration menu.
Ok, found the log file. Looks like I may have a malformed tag. I’ll try that and see if it helps.
Didn’t know about the logfile other than the one on the front-end (which constantly spams me with things not responding in the right amount of time) so thank you for pointing me in the right direction.
