Fan template not recognizing preset and speed commands
I have configured a dummy air humidifier (off + 4 intensity modes) as a fan, because it seems to be best suited for such case. I have the following definition in my config:
# https://www.home-assistant.io/integrations/fan.template/
fan:
    fans:
      duka:
        friendly_name: "DUKA nawilzacz"
        value_template: "{{ int(states('counter.dukastate')) != 0 }}"
        percentage_template: "{{ float(states('counter.dukastate'))/4 }}"
        preset_mode_template: "{{ state_attr('fan.duka','preset_modes')[int(states('counter.dukastate'))]}}"
        turn_on:
          service: script.dukaspeed
            percentage: "{{ 0.25 }}"
        turn_off:
            percentage: "{{ 0.0 }}"
        set_percentage:
            percentage: "{{ float(percentage) }}"
        set_preset_mode:
          service: script.dukapreset
            preset_mode: "{{ preset_mode }}"
        speed_count: 4
        preset_modes:
          - 'off'
          - 'interested'
          - 'aroused'
          - 'horny'
          - 'nympho'
As you see set_percentage uses the exact same script as turn_on and turn_off. Yet on/off works and percentaga fails with “Failed to call service fan/set_percentage. Set of Tasks/Futures is empty.” Similarly with preset: “Service script.dukamode called service fan.set_preset_mode which was not found.” Is this a bug?
Another strange failure happens for these buttons:
type: buttons
entities:
  - entity: media_player.denon_avr_x1400h
    show_icon: true
    show_name: true
    icon: mdi:circle-small
    tap_action:
      action: call-service
        percentage: '{{ float(0.2) }}'
    show_icon: true
    show_name: true
    icon: mdi:pinterest
    tap_action:
        percentage: '{{ float(0.4) }}'
    show_icon: true
    show_name: true
    icon: mdi:audio-input-xlr
    tap_action:
        percentage: '{{ float(0.6) }}'
    show_icon: true
    show_name: true
    tap_action:
        percentage: '{{ float(0.8) }}'
They call exactly the same script, yet pressing them gives: “Failed to call service script/dukaspeed. TypeError: unsupported operand type(s) for +: ‘int’ and ‘str’”
Can anyone help?
