Faster way to reload automations?
I just started with HA and I’m trying to write some automations and blueprints in yaml. Debugging is a bit slow, because I couldn’t find a real fast way to repload changed automations or blueprints. The fastest way I found is pressing c and scrolling down to “Reload Automations”. But the scrolling is a bit unnerving to be honest… Is there a faster possibility, perhaps just assigning “Reload automations” to a hot-key? Or to sort the entries which are appearing when pressing c to make “reload automations” on top?
c → type reload au → select first choice
not possible
You can make a button in your frontend that reloads automations by calling the service via tap_action
developers tools —> yaml/yaml configuration reloading?
or create an automation?
service: automation.reload
data: {}
Thank you, both works fine. Very helpfull.
