Hi all,
I have purchased a ws2811 led strip 5m strip with 30 led per meter addressable in groups of 3, 12 v power adapter, and a nodemcuv3 and various connectors. I am trying to make a light strip but I am not having very much luck. The lights will not respond to control from the nodemcu, even though the logs show the mqtt messages arriving from home assistant. The lights are always on when the data wire is connected but will also flicker.
I have the lights wired directly to the power supply + and -
The nodemcu is powered via usb for now, and I have the data wire connected to pin d5.
Here is my config file:
esphomeyaml:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: 'mystery24'
password: '********'
# Enable logging
logger:
# Enable Home Assistant API
api:
password: '******'
ota:
password: '*******'
mqtt:
broker: 192.168.2.9
username: wallo-mqtt
password: ******
light:
- platform: fastled_clockless
chipset: WS2811
rgb_order: BRG
pin: D5
num_leds: 150
name: "Lloyd's Desk LED Lights"
effects:
- random:
- strobe:
- flicker:
- addressable_rainbow:
name: Rainbow Effect With Custom Values
speed: 10
width: 50
- addressable_color_wipe:
name: Color Wipe Effect With Custom Values
colors:
- red: 100%
green: 100%
blue: 100%
num_leds: 1
- red: 0%
green: 0%
blue: 0%
num_leds: 1
add_led_interval: 100ms
reverse: False
Here is a picture to assist as well. Thanks in advance for any input.
