FeatherS3 Deep Sleep wakes up for no reason?
Hi
So I’ve got an ESP32 S3 & configured it to deep sleep after 120s of being idle, which seems to work fine. My issue is that it wakes up randomly & I cant figure out why.
The push button (input 12) is connected to 3.3v LDO1 & the input is configured with a pull down resistor, putting a meter on the input shows it stays off until the switch is pushed & monitoring ‘deep_sleep_pin’ seems to imply its not randomly toggling.
Monitoring the wakeup wause gets a state of 2 which implies its an RTC pin waking the system up, but how? The configured pin looks okay…
What could be causing the system to keep waking up?
binary_sensor:
  - platform: gpio
    pin:
      number: 12
      allow_other_uses: true
      mode:
        input: true
        pulldown: true
    on_press:
      then:
        - logger.log: "Sleep Prevented"
        - deep_sleep.prevent: deep_sleep_1
        - script.stop: start_sleep
    on_release:
      then:
        - logger.log: "Sleep Allowed"
        - deep_sleep.allow: deep_sleep_1
        - script.execute: start_sleep
  - platform: gpio
    pin:
      number: 34
      mode:
        input: true
        pulldown: true
    on_press:
      then:
        - logger.log: "Charging"
    on_release:
      then:
        - logger.log: "Battery"
# Deep Sleep
deep_sleep:
  wakeup_pin:
    number: 12
    mode:
      input: True
      pulldown: True
  wakeup_pin_mode: IGNORE
script:
  - id: start_sleep
    then:
      - delay: 120s
      - deep_sleep.enter:
          sleep_duration: 3600min
