Feature Request: 1-wire custom integration
Hi friends.
As you know, Home Assistant maintainers have decided to deprecate the 1-wire integration, at the same time as the rpi-gpio integration (it will be available until May 2022).
Fortunatelly @thecode has decided to keep the rpi-gpio integration as a custom component (GitHub - thecode/ha-rpi_gpio: Home Assistant Raspberry Pi GPIO Integration). But I have not found anything about the 1-wire integration.
Do you know if there is any 1-wire custom component? I think there is a lot of people using it, and it would be very interesting if it continues to be maintained, even if it is as a custom component.
Thanks!!
Nothing new? So, 1-wire will dissapear in June 1th without alternatives? :disappointed_relieved:
I too need 1-wire support in HA on RPI - have you found a solution?
PS. found this on github - will try it out during this week:
