Feature Request: Add iDrate Reticulation Support to iZone Integration
Current Behavior
  • The iZone integration currently only supports AC control and zones
  • iDrate reticulation controllers, despite using the same WiFi bridge and API structure as the AC units, are not detected or controlled
Desired Behavior
  • Detection and control of iDrate reticulation controllers through the existing iZone integration
  • Support for reticulation zones/valves control
  • Support for scheduling and manual operation
  • Integration with Home Assistant’s irrigation capabilities
Technical Details
  1. The iDrate controller uses the same network bridge as iZone AC units
  2. API documentation is available at: Irrigation | iZone Developer
  3. The controller is accessible through the same IP address as the AC unit
  4. The API follows similar REST patterns to the existing AC control endpoints
Benefits
  • Unified control of iZone devices in Home Assistant
  • Complete smart home irrigation control
  • Leverages existing network discovery and authentication methods
  • Would benefit all iZone users with iDrate controllers
Additional Information
  • iDrate controllers are part of the iZone ecosystem
  • The existing integration already handles device discovery and authentication
  • Only requires implementation of additional API endpoints for reticulation control
  • Would enhance Home Assistant’s irrigation control capabilities
References
