[Feedback / Request] Session resets / reloads after time duration of inactivity
When working with NodeRED - if I step away for five minutes (or some set duration) and then come back; my NR session resets / reloads - from inactivity I presume.
Is there a way to either increase this timer; or disable it entirely - per a user setting so that this reload function doesn’t occur so that I can just keep working as I left off?
I don’t see a need for it to reset like that so quickly.
Use your home assistant ip address and replace :8123 with 1880
Genius.
I have bookmarked this. Thank you kindly!
It doesn’t work on my end.
After entering HA credentials, it ends up with “Cannot GET /a0d7b954_nodered/dashboard” output.
Why should it work with the port changed?
1880 is the default port for the nr addon. You should be able to check on the addon configuration page of it’s been changed.
There is also a direct link on the addon page, click the open web ui button. Does that take you to node red?
