Feedback wanted: local read-only Home Assistant configuration audit tool
Hi everyone,
I have been experimenting with a small local tool for reviewing Home Assistant configuration exports and would appreciate feedback from people who run more varied setups than mine.
The project is called Home Assistant Audit Lite:
The goal is intentionally limited:
  • run locally,
  • read only an exported/redacted Home Assistant configuration folder,
  • do not connect to Home Assistant,
  • do not call the network,
  • do not modify any files,
  • avoid printing secret values,
  • produce a Markdown or JSON report with review prompts.
It currently checks things like:
  • presence of common config files,
  • secret-like key names without printing values,
  • references to entities in automations/scripts/config,
  • optionally redacted log files for WARNING/ERROR/Traceback patterns,
  • basic Energy dashboard sanity checks around device_class, state_class, units like W/kW/Wh/kWh/mÂł,
  • recorder configuration hints,
  • MQTT / Zigbee2MQTT sanity hints,
  • backup/update readiness review prompts.
Example usage:
python3 ha-audit-lite-v0.2.py /path/to/ha-export /path/to/report.md
JSON output is also supported:
python3 ha-audit-lite-v0.2.py /path/to/ha-export /path/to/report.json --format json
The findings are meant as review prompts, not as proof that a production setup is broken. The tool uses conservative line/regex analysis rather than trying to fully understand every Home Assistant integration or template.
I am mainly looking for feedback on:
  1. Are there checks that would be useful for real Home Assistant maintenance but are still safe to run locally?
  2. Are any current checks likely to create too much noise or misleading output?
  3. Are there common configuration patterns this kind of tool should avoid flagging?
  4. Is the “local, read-only, no upload” boundary clear enough?
I am especially interested in feedback from people with Energy dashboards, MQTT/Zigbee2MQTT setups, larger automation files, or package-based configurations.
Thanks.
