I have a Feit Electric A19 800lm RGBCCT Bulb flashed with Tasmota installed and synced up to Home Assistant. When I try to turn it on from Home Assistant, the bulb will physically turn on but the Home Assistant status is not reflected properly; toggle flicks to on and then within a second goes to back off but the bulb stays on. In the Tasmota console, I can see the request from Home Assistant to turn the light on and Tasmota shows on.
Not sure what the issue is here or exactly how to troubleshoot it.
- Could it be that I have possible WiFi connection issues? (I’m doubtful that this is the issue since I can see the request from Home Assistant in the Tasmota console.)
- Is there something wrong with my configuration below?
- Is the light bulb not reporting it’s status after making the call?
I got my configuration template from here.
light:
- platform: mqtt
name: "Front Door Light"
command_topic: "cmnd/Front_Door_Light/POWER"
state_topic: "tele/Front_Door_Light/STATE"
state_value_template: "{{value_json.POWER}}"
availability_topic: "tele/Front_Door_Light/LWT"
brightness_command_topic: "cmnd/Front_Door_Light/Dimmer"
brightness_state_topic: "tele/Front_Door_Light/STATE"
brightness_scale: 100
on_command_type: "last"
brightness_value_template: "{{value_json.Dimmer}}"
white_value_state_topic: "tele/Front_Door_Light/STATE"
white_value_command_topic: "cmnd/Front_Door_Light/white"
white_value_scale: 100
white_value_template: "{{ value_json.Channel[3] }}"
rgb_command_topic: "cmnd/Front_Door_Light/Color2"
rgb_state_topic: "tele/Front_Door_Light/STATE"
rgb_value_template: "{{value_json.Color.split(',')[0:3]|join(',')}}"
effect_command_topic: "cmnd/Front_Door_Light/Scheme"
effect_state_topic: "tele/Front_Door_Light/STATE"
effect_value_template: "{{value_json.Scheme}}"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
qos: 1
retain: false
