i´m trying to figure out how to read the energy consumption from my old ferraris counter. (96rounds per kwh)
I have a tcrt5000 sensor attached to a wemos d1 mini.
Now I´m unsure if my setup is correct so far and if you have any further advices.
Also, you need a multiplier of 0.625, I think. The pulse-counter measures in pulses per minute, and you need to adjust it so that this is the same as kW.
96 pulses in an hour would be 1kW, which is the same as 96/60 pulses per minute, so you need to multiply by 60/96=0.625 to get to the desired output number of 1. This does mean your minimum resolution will be 625W, which for typical house base load will result in a very “jumpy” graph with 0W in some slots and 625W in others. The long-term average will be accurate, though — you could set up a “smoothed” template filter in HA.
Ah, thanks for your explanation!
I will change the multiplier
625W is indeed very “jumpy” - but as a starter it will do the job.
Later I will have a look at monitoring with clamps. But this looks much more complicated at a first look.
Do you have any example how this “smoothed” template filter could look like? I’ve tried it with the statistics platfrom, but the values doesn’t make sense:
