FFMPEG Errors in Frigate
Trying to resolve my ffmpeg errors, here’s what it’s constantly outputting below:
2026-01-28 21:17:33.338540  2026-01-28 21:13:34.204998568
2026-01-28 21:17:33.338542  2026-01-28 21:13:34.204999218
2026-01-28 21:13:34.213354600  [2026-01-28 21:13:34] frigate.record.maintainer      WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2026-01-28 21:13:34.213854601  [2026-01-28 21:13:34] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2026-01-28 21:13:34.232220500  [2026-01-28 21:13:34] frigate.record.maintainer      WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2026-01-28 21:13:34.232408863  [2026-01-28 21:13:34] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2026-01-28 21:13:44.018096179  [2026-01-28 21:13:44] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2026-01-28 21:14:26.060866405  [2026-01-28 21:14:26] frigate.embeddings.embeddings  INFO    : Embedded 1420 thumbnails and 0 descriptions in 121.7 seconds
2026-01-28 21:14:33.678531944  [2026-01-28 21:14:33] watchdog.Backyard              INFO    : Backyard exceeded fps limit. Exiting ffmpeg...
2026-01-28 21:14:33.678827056  [2026-01-28 21:14:33] watchdog.Backyard              INFO    : Waiting for ffmpeg to exit gracefully...
2026-01-28 21:14:33.720206908  [2026-01-28 21:14:33] watchdog.Driveway              INFO    : Driveway exceeded fps limit. Exiting ffmpeg...
2026-01-28 21:14:33.720774978  [2026-01-28 21:14:33] watchdog.Driveway              INFO    : Waiting for ffmpeg to exit gracefully...
2026-01-28 21:14:43.478497449  [2026-01-28 21:14:43] frigate.record.maintainer      WARNING : Unable to keep up with recording segments in cache for Porch. Keeping the 6 most recent segments out of 9 and discarding the rest...
2026-01-28 21:14:58.817552375  [2026-01-28 21:14:58] frigate.video                  ERROR   : Driveway: Unable to read frames from ffmpeg process.
2026-01-28 21:14:58.817919695  [2026-01-28 21:14:58] frigate.video                  ERROR   : Driveway: ffmpeg process is not running. exiting capture thread...
2026-01-28 21:14:58.860303945  [2026-01-28 21:14:58] watchdog.Driveway              ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2026-01-28 21:14:58.860578324  [2026-01-28 21:14:58] ffmpeg.Driveway.detect         ERROR   : [segment @ 0x5645a5f4a580] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2026-01-28 21:14:58.860759517  [2026-01-28 21:14:58] ffmpeg.Driveway.detect         ERROR   : [rtsp @ 0x5645a5f1e3c0] RTP: PT=61: bad cseq 429b expected=4d38
2026-01-28 21:14:58.861654885  [2026-01-28 21:14:58] ffmpeg.Driveway.detect         ERROR   : [rtsp @ 0x5645a5f1e3c0] RTP: PT=60: bad cseq ed85 expected=2c8a
2026-01-28 21:14:58.863638544  [2026-01-28 21:14:58] watchdog.Driveway              INFO    : Restarting ffmpeg...
2026-01-28 21:15:03.678916717  [2026-01-28 21:15:03] watchdog.Backyard              INFO    : FFmpeg did not exit. Force killing...
2026-01-28 21:15:03.682102532  [2026-01-28 21:15:03] frigate.video                  ERROR   : Backyard: Unable to read frames from ffmpeg process.
2026-01-28 21:15:03.682102532  [LOGGING] Last message repeated 45 times
2026-01-28 21:15:03.687730587  [2026-01-28 21:15:03] watchdog.Backyard              ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2026-01-28 21:15:03.687884846  [2026-01-28 21:15:03] frigate.video                  ERROR   : Backyard: ffmpeg process is not running. exiting capture thread...
2026-01-28 21:15:03.688187003  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : [segment @ 0x55a0bd455580] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2026-01-28 21:15:03.688956987  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : [rtsp @ 0x55a0bd4293c0] RTP: PT=61: bad cseq 9261 expected=e00c
2026-01-28 21:15:03.689650149  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : [rtsp @ 0x55a0bd4293c0] RTP: PT=60: bad cseq 4298 expected=d423
2026-01-28 21:15:03.690288172  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003278834, next:27864250 st:1 invalid dropping
2026-01-28 21:15:03.690771757  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003278834, next:27864250 invalid dropping st:1
2026-01-28 21:15:03.691049290  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003279798, next:27928250 st:1 invalid dropping
2026-01-28 21:15:03.691782419  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003279798, next:27928250 invalid dropping st:1
2026-01-28 21:15:03.692739613  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003281714, next:27992250 st:1 invalid dropping
2026-01-28 21:15:03.692914430  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003281714, next:27992250 invalid dropping st:1
2026-01-28 21:15:03.693422043  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003281724, next:28056250 st:1 invalid dropping
2026-01-28 21:15:03.694005764  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003281724, next:28056250 invalid dropping st:1
2026-01-28 21:15:03.694404959  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003283633, next:28120250 st:1 invalid dropping
2026-01-28 21:15:03.695189668  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003283633, next:28120250 invalid dropping st:1
2026-01-28 21:15:03.695546386  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003284594, next:28184250 st:1 invalid dropping
2026-01-28 21:15:03.695785124  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003284594, next:28184250 invalid dropping st:1
2026-01-28 21:15:03.696092571  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003285554, next:28248250 st:1 invalid dropping
2026-01-28 21:15:03.696879219  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003285554, next:28248250 invalid dropping st:1
2026-01-28 21:15:03.697130468  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003286514, next:28312250 st:1 invalid dropping
2026-01-28 21:15:03.697857043  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003286514, next:28312250 invalid dropping st:1
2026-01-28 21:15:03.698289480  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003287472, next:28376250 st:1 invalid dropping
2026-01-28 21:15:03.698622154  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003287472, next:28376250 invalid dropping st:1
2026-01-28 21:15:03.699077446  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003288434, next:28440250 st:1 invalid dropping
2026-01-28 21:15:03.699273027  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003288434, next:28440250 invalid dropping st:1
2026-01-28 21:15:03.699480532  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003289390, next:28504250 st:1 invalid dropping
2026-01-28 21:15:03.699789728  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003289390, next:28504250 invalid dropping st:1
2026-01-28 21:15:03.700223135  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003290350, next:28568250 st:1 invalid dropping
2026-01-28 21:15:03.700791101  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003290350, next:28568250 invalid dropping st:1
2026-01-28 21:15:03.701124653  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003291318, next:28632250 st:1 invalid dropping
2026-01-28 21:15:03.701580683  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003291318, next:28632250 invalid dropping st:1
2026-01-28 21:15:03.701899128  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003292275, next:28696250 st:1 invalid dropping
2026-01-28 21:15:03.702538189  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003292275, next:28696250 invalid dropping st:1
2026-01-28 21:15:03.702807477  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003293232, next:28760250 st:1 invalid dropping
2026-01-28 21:15:03.703284643  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003293232, next:28760250 invalid dropping st:1
2026-01-28 21:15:03.703654734  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : DTS 2003294192, next:28824250 st:1 invalid dropping
2026-01-28 21:15:03.704073975  [2026-01-28 21:15:03] ffmpeg.Backyard.detect         ERROR   : PTS 2003294192, next:28824250 invalid dropping st:1
2026-01-28 21:15:03.704757698  [2026-01-28 21:15:03] watchdog.Backyard              INFO    : Restarting ffmpeg...
2026-01-28 21:15:08.456085016  [2026-01-28 21:15:08] frigate.record.maintainer      WARNING : Unable to keep up with recording segments in cache for Porch. Keeping the 6 most recent segments out of 9 and discarding the rest...
2026-01-28 21:15:08.456345927  [2026-01-28 21:15:08] frigate.record.maintainer      WARNING : Unable to keep up with recording segments in cache for SideYard. Keeping the 6 most recent segments out of 8 and discarding the rest...
2026-01-28 21:15:09.098754976  [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2026-01-28 21:17:33.338588  2026-01-28 21:15:09.098757289
2026-01-28 21:15:09.098758601  OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2026-01-28 21:17:33.338590  2026-01-28 21:15:09.098759218
2026-01-28 21:17:33.338592  2026-01-28 21:15:09.098759738
2026-01-28 21:15:09.104549791  [2026-01-28 21:15:09] frigate.record.maintainer      WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2026-01-28 21:15:09.104719592  [2026-01-28 21:15:09] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2026-01-28 21:16:38.609793322  [2026-01-28 21:16:38] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
2026-01-28 21:16:53.693614681  [2026-01-28 21:16:53] watchdog.Backyard              INFO    : Backyard exceeded fps limit. Exiting ffmpeg...
2026-01-28 21:16:53.693952224  [2026-01-28 21:16:53] watchdog.Backyard              INFO    : Waiting for ffmpeg to exit gracefully...
2026-01-28 21:16:58.864377050  [2026-01-28 21:16:58] watchdog.Driveway              INFO    : Driveway exceeded fps limit. Exiting ffmpeg...
2026-01-28 21:16:58.864661301  [2026-01-28 21:16:58] watchdog.Driveway              INFO    : Waiting for ffmpeg to exit gracefully...
2026-01-28 21:17:18.614178921  [2026-01-28 21:17:18] frigate.record.maintainer      WARNING : Unable to keep up with recording segments in cache for SideYard. Keeping the 6 most recent segments out of 7 and discarding the rest...
2026-01-28 21:17:23.695198238  [2026-01-28 21:17:23] watchdog.Backyard              INFO    : FFmpeg did not exit. Force killing...
2026-01-28 21:17:23.701497872  [2026-01-28 21:17:23] frigate.video                  ERROR   : Backyard: Unable to read frames from ffmpeg process.
2026-01-28 21:17:23.701497872  [LOGGING] Last message repeated 3 times
2026-01-28 21:17:23.702430295  [2026-01-28 21:17:23] watchdog.Backyard              ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2026-01-28 21:17:23.702601737  [2026-01-28 21:17:23] frigate.video                  ERROR   : Backyard: ffmpeg process is not running. exiting capture thread...
2026-01-28 21:17:23.702875064  [2026-01-28 21:17:23] ffmpeg.Backyard.detect         ERROR   : [rtsp @ 0x559c75d3b3c0] RTP: PT=60: bad cseq 0bc0 expected=3af1
2026-01-28 21:17:23.703088602  [2026-01-28 21:17:23] ffmpeg.Backyard.detect         ERROR   : [rtsp @ 0x559c75d3b3c0] RTP: PT=61: bad cseq f378 expected=d2a0
2026-01-28 21:17:23.703233244  [2026-01-28 21:17:23] watchdog.Backyard              INFO    : Restarting ffmpeg...
2026-01-28 21:17:28.865284404  [2026-01-28 21:17:28] watchdog.Driveway              INFO    : FFmpeg did not exit. Force killing...
2026-01-28 21:17:28.868848304  [2026-01-28 21:17:28] frigate.video                  ERROR   : Driveway: Unable to read frames from ffmpeg process.
2026-01-28 21:17:28.868848304  [LOGGING] Last message repeated 3 times
2026-01-28 21:17:28.869490104  [2026-01-28 21:17:28] watchdog.Driveway              ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2026-01-28 21:17:28.869717716  [2026-01-28 21:17:28] frigate.video                  ERROR   : Driveway: ffmpeg process is not running. exiting capture thread...
2026-01-28 21:17:28.869955041  [2026-01-28 21:17:28] ffmpeg.Driveway.detect         ERROR   : [rtsp @ 0x561bb2bc33c0] RTP: PT=60: bad cseq b5da expected=48b6
2026-01-28 21:17:28.870114320  [2026-01-28 21:17:28] ffmpeg.Driveway.detect         ERROR   : [rtsp @ 0x561bb2bc33c0] RTP: PT=61: bad cseq e929 expected=45bb
2026-01-28 21:17:28.870282167  [2026-01-28 21:17:28] ffmpeg.Driveway.detect         ERROR   : [segment @ 0x561bb2bef580] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2026-01-28 21:17:28.870398324  [2026-01-28 21:17:28] watchdog.Driveway              INFO    : Restarting ffmpeg...
2026-01-28 21:17:29.086935215  [ WARN:[email protected]] global cap.cpp:175 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2026-01-28 21:17:33.338607  2026-01-28 21:17:29.086937536
2026-01-28 21:17:29.086938957  OpenCV(4.11.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2026-01-28 21:17:33.338610  2026-01-28 21:17:29.086939562
2026-01-28 21:17:33.338611  2026-01-28 21:17:29.086940073
2026-01-28 21:17:29.092357058  [2026-01-28 21:17:29] frigate.record.maintainer      WARNING : Failed to probe corrupt segment /tmp/cache/[email protected]
2026-01-28 21:17:29.092534886  [2026-01-28 21:17:29] frigate.record.maintainer      WARNING : Discarding a corrupt recording segment: /tmp/cache/[email protected]
Here’s my config:
mqtt:
  enabled: true
  host: 192.168.1.110
  port: 1883
ffmpeg:
  hwaccel_args: preset-vaapi
  path: "7.0"
  output_args:
    record: preset-record-generic-audio-aac
go2rtc:
  streams:
    Porch:
      - ffmpeg:http://192.168.50.10/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.10:554/h264Preview_01_main
    Porch_sub:
      - ffmpeg:http://192.168.50.10/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.10:554/h264Preview_01_sub
    Backyard:
      - ffmpeg:http://192.168.50.11/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.11:554/h264Preview_01_sub
    Driveway:
      - ffmpeg:http://192.168.50.12/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.12:554/h264Preview_01_sub
    SideYard:
      - ffmpeg:http://192.168.50.13/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.13:554/h264Preview_01_main
    SideYard_sub:
      - ffmpeg:http://192.168.50.13/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=#video-copy#audio=copy#audio=opus"
      - rtsp://admin:@192.168.50.13:554/h264Preview_01_sub
record:
  enabled: true
  retain:
    days: 14
    mode: all
  alerts:
    retain:
      days: 30
      mode: motion
snapshots:
  enabled: true
  clean_copy: true
  timestamp: false
  crop: true
  retain:
    default: 20
    objects:
      person: 30
objects:
  track:
    - person
    - car
    - cat
    - dog
cameras:
  Porch: # <------ Name the camera
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Porch # <----- The stream you want to use for detection
          input_args: preset-rtsp-restream
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/Porch_sub
          roles:
            - detect
    motion:
      threshold: 30
      contour_area: 10
      improve_contrast: true
    objects:
      filters:
        car:
          mask:
            - 0.329,0.037,0.138,0.094,0.039,0.169,0.139,0.639,0.437,0.681,0.569,0.469
            - 0,0.145,0.199,0.052,0.641,0,0,0
        truck:
          mask:
            - 0.137,0.1,0.035,0.181,0.138,0.641,0.42,0.679,0.568,0.475,0.332,0.035
            - 0,0.15,0.007,0.005,0.626,0.005,0.198,0.053
        cat:
          mask:
            0.691,0.416,0.776,0.411,0.793,0.59,0.755,0.587,0.703,0.601,0.698,0.516
    zones: {}
  Backyard:
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Backyard
          roles:
            - detect
            - record
    motion:
      threshold: 30
      contour_area: 10
    objects:
      filters:
        car:
          mask: 0.012,0.012,0.013,0.978,0.987,0.979,0.993,0.014
        truck:
          mask: 0.012,0.023,0.014,0.974,0.987,0.977,0.992,0.013
        person:
          mask: 0.323,0.691,0.391,0.679,0.456,0.957,0.368,0.99
    zones: {}
    review: {}
  SideYard:
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/SideYard # <----- The stream you want to use for detection
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/SideYard_sub
          roles:
            - detect
    objects:
      filters:
        car:
          mask: 0.005,0,1,0,0,0,0.012,0.989,1,0.988,1,0
  Driveway:
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Driveway
          roles:
            - record
            - detect
    motion:
      mask:
        0,0.363,0.254,0.206,0.296,0.289,0.351,0.238,0.362,0.309,0.375,0.422,0.418,0.452,0.459,0.467,0.448,0.555,0.469,0.61,0.493,0.543,0.528,0.545,0.503,0.681,0.515,0.89,0.488,1,0.389,1,0.027,1,0,1
      threshold: 40
      contour_area: 10
    objects:
      filters:
        cat: {}
        car:
          mask:
            0.814,0.221,1,0.315,1,1,0.659,1,0.453,1,0,1,0.011,0.506,0,0.325,0.414,0.083,0.644,0.146,0.419,0.157,0.694,0.057
detectors:
  ov:
    type: openvino
    device: GPU
model:
  width: 300
  height: 300
  input_tensor: nhwc
  input_pixel_format: bgr
  path: /openvino-model/ssdlite_mobilenet_v2.xml
  labelmap_path: /openvino-model/coco_91cl_bkgr.txt
detect:
  enabled: true
  width: 320
  height: 320
  fps: 5
version: 0.16-0
semantic_search:
  enabled: true
  reindex: true
  model_size: small
Both sideyard and porch are Reolink CX410 POE, backyard is Duo 3 POE, driveway is Duo Floodlight POE. Frigate is running in docker on Linux Mint 21.3 w/ i5-11400 CPU. Any help is much appreciated :slight_smile:
