Hello! Newbie here so bear with me
A couple of months ago I started with HA as I needed a solution for the lights in my home theatre, as I wanted them to go off/on when starting/stopping a movie.
For this, I’ve been using a Fibaro Dimmer2 with an Aotec Z stick Gen5 and I created the necessary automations. Everything has been working fine until recently.
Due to a power failure, HA didn’t worked as previous and I started from scratch. The automations are correct and the devices are all available and alive.
However; The Fibaro Dimmer2 doesn’t respond anymore to the automations. I’ve noticed that the Dimmer2 device information mentions “highest security: S0 Legacy”. From what I can remember, this wasn’t mentioned in the past.
Is the problem related to this security thing? If so, what is the solution to this problem? I’ve already tried to interview/heal the device and even removed it. A reset on the Dimmer2 side has been done as well but no matter what I do, the highest security thing stays on S0 Legacy (even when I try adding the device as non-secure).
Thanks in advance for all your feedback!
