Since a few months I’m a happy Home Assistant user. It runs on a Raspberry Pi 3 with a Aeon Labs Aeotec Gen 5 Z-Wave USB stick.
It’s connected to different z-wave switches.
The problem is with the Fibaro FGS221 not reporting the status. When I flip the switch on the wall the light turns ons, but the state of the switch keeps off inside Home Assistant. In Home Assistant I can controll the light, but when the wall switch is used there is a missmatch so I need to tap it twice.
I already did a reset of the switch and re-added it to Home Assistant. Is there a way to let the wall switch report his status back to Home Assistant?
I have the same problem with the Fibaro Wall Plug Gen5.
Works fine with Alexa and Siri, but the Status in HA does not update most of the time.
So I have to click twice.
I habe no solution.
as written in the linked topic the issue seems to be resolved with this configuration for sw1:
{ zwave=“7:command=SWITCH_BINARY” }
and this for sw2:
{ zwave=“7:2:command=SWITCH_BINARY” }
now all the wall switches are updating their statuses to openhab.
I don’t have a clue on how to do this kind of config inside Home Assistant. Is there maybe someone with some tips on this?
Anyone has any info about how to fix this? It seems to work in openhab, so it does not seem to be an openzwave issue. I have a couple of FGS221 devices. They work properly with the Fibaro home center, but not with Home Assistant.
