Fibaro FGFS101 Flood sensors
I have 3 FGFS101 flood sensors with firmware 26.26. I had these integrated on my prior ozw integration without issues. They reported 3 values, a flood sensor, tamper sensor and temperature. I recently upgrated to the new zwavejs integration with the zwavejs2mqtt control page.
on my zwavejs2mqtt control panel i am seeing multiple sensors, including the temperature but on the zwave integration entities the temperature seems to drop to unavailable. it was previously working with updated temps every 5 minutes on the ozw network.
not sure why, but im wondering is this an openzwave vs zwavejs difference causing the drop of the temp readings? any way to recover the temperature readings?
thanks
Some Integrations create some entities as disabled. You might want to check that.
It creates the entity but never updates it
Old topic but I have the exact same issue. Did you find a solution, @SmittyMD ? 26.26 - same temp drop, etc.
Merry Christmas. Unfortunately no luck. The sensors intermittently report temps ever since switching from open zwave to zwavejs, but will comes back with an unavailable result Anit half of the time.
Same thing. I tried updating the update interval from the default of 300s to 10s (powered by an external power supply so battery usage isn’t an issue) but the device won’t store the 10s value.
