Fibaro FGS-213/FGS-223 not sending scene notifications over multiple hops
I have a bunch of Fibaro switches, and when I enable scene notifications in their configuration for single/double/triple click I see them in HA and zwavejs2mqtt UI, but only when those devices are communicating with the controller directly. When I move those devices farther away, so that there are two hops or more between the device and the controller, no notifications are delivered.
In the same network, the smart modules (FGS-214/FGS-224) deliver scene notifications just fine, even over several hops.
The switches don’t use any encryption, while the smart modules use S2 encryption.
I am using the Aeotec Z-Stick Gen5+.
Does anybody know why that would be happening or how to fix it?
Thanks!
Hello, I believe I have the same problem with a FGS-223. Have you managed to find a solution or workaround?. Thanks!
Hi! Unfortunately there is no solution… FGS-213/223 only deliver scene events when they are directly connected to the controller. See here: Fibaro Forum
Thank for your answer!
