I hooked up my sliding gate to a FGS 224.
It’s set up as a dry contact with one wire to IN and the other wire to Q1.
That works fine.
Now i want to open the gate also with a physical button so i thought i could use the S1 input.
But the S1 needs a voltage and in my case it’s hooked up to 220V
When there goes 220V through S1 i will blow up my motor !!
What am i doing wrong ?
Thx for your reply.
That is the solution.
I installed dozens of fibaro modules but that were all single or double switches.
This one is slightly different but it works now.
Besides that the documentation of fibaro hardware is the worst i’ve ever seen.
But the hardware itself is as far as i know one of the best on the market.
Before i only used fibaro but i left and went to HA.
