Hi! I’m using HA since few days (I was on Jeedom before, French domotic solution) and I’ve got some issue with Z-Wave integration, precisely the Fibaro FGT-001 (heat controller).
There’s a parameter which can add some features to the product:
As you can see, the value has to be something like 1, 2, 3, 4, 5, 8, …, 31. Firstly, the hint says incoherent values. Secondly, I simple can’t set the parameter (it stays at 1, default value).
Here’s the log:
2019-11-16 22:07:22.512 Info, Node010, Value::Set - COMMAND_CLASS_CONFIGURATION - Additional functions - 2 - 1 - 31
2019-11-16 22:07:22.512 Info, Node010, Configuration::Set - Parameter=2, Value=31 Size=4
2019-11-16 22:07:22.512 Detail, Node010, Queuing (Send) ConfigurationCmd_Set (Node=10): 0x01, 0x0f, 0x00, 0x13, 0x0a, 0x08, 0x70, 0x04, 0x02, 0x04, 0x00, 0x00, 0x00, 0x1f, 0x25, 0x4e, 0xe7
2019-11-16 22:07:22.512 Detail, Node010, Queuing (Send) ConfigurationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x70, 0x05, 0x02, 0x25, 0x4f, 0xf2
2019-11-16 22:07:22.512 Info, Node010, Sending (Send) message (Callback ID=0x4e, Expected Reply=0x13) - ConfigurationCmd_Set (Node=10): 0x01, 0x0f, 0x00, 0x13, 0x0a, 0x08, 0x70, 0x04, 0x02, 0x04, 0x00, 0x00, 0x00, 0x1f, 0x25, 0x4e, 0xe7
2019-11-16 22:07:22.520 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-16 22:07:22.521 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2019-11-16 22:07:23.806 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x4e, 0x00, 0x00, 0x81, 0x24
2019-11-16 22:07:23.806 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x4e received (expected 0x4e)
2019-11-16 22:07:23.806 Info, Node010, Request RTT 1293 Average Request RTT 865
2019-11-16 22:07:23.806 Detail, Expected callbackId was received
2019-11-16 22:07:23.806 Detail, Expected reply was received
2019-11-16 22:07:23.806 Detail, Message transaction complete
2019-11-16 22:07:23.806 Detail, Node010, Removing current message
2019-11-16 22:07:23.806 Info, Node010, Sending (Send) message (Callback ID=0x4f, Expected Reply=0x04) - ConfigurationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x70, 0x05, 0x02, 0x25, 0x4f, 0xf2
2019-11-16 22:07:23.814 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-16 22:07:23.814 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2019-11-16 22:07:23.835 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x4f, 0x00, 0x00, 0x03, 0xa7
2019-11-16 22:07:23.835 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x4f received (expected 0x4f)
2019-11-16 22:07:23.835 Info, Node010, Request RTT 28 Average Request RTT 446
2019-11-16 22:07:23.835 Detail, Expected callbackId was received
2019-11-16 22:07:23.854 Detail, Node010, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x0a, 0x04, 0x22, 0x01, 0x01, 0x02, 0xdf
2019-11-16 22:07:23.854 Info, Node010, Response RTT 47 Average Response RTT 52
2019-11-16 22:07:33.807 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-16 22:07:33.807 Detail, Node010, Removing current message
2019-11-16 22:07:33.807 Detail, Node010, Notification: Notification - TimeOut
I hope someone has a solution for me, the product works fine with other domotic solution so I hope it could work with HA!
I got no issue with other Z-Wave product
