FIBARO RGBW - z-wave JS
i am trying to create dashboard for my RGBW light.
Controller is FIbaro and it add to to HS.
I can se 4 color channels and one main.
But i don’t know how a to create dashboard for controlling the Colors RGB + W separately.
I want to set up somethin like this:
I found in unit setup “Color Switch” where i can set RGB color by HEX.
Some guide will be good, it try lfind some info …
Unfortunately, there’s an issue with the Fibaro RGBW controller and Z-Wave JS at the moment. For some reason Z-Wave JS only sees 5 light channels, instead of 6 - and the missing one is what provides the Color wheel. See
Thank you i miss that :frowning:
So i will wait till update …
